Candy CDF622 circulation problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Candy CDF622 circulation problem
  • #60863
    Brendon
    I have a problem with my Candy dishwasher. It starts the cycle and once the water level is correct and the circulation pumps starts, the pumps keep cutting out and just goes into a start stop cycle. When this happens the lights on the front flash as the pumps stops.
    The drain pumps works and the circulation pumps is also fine, so I think it must be a sensor to something cutting out.
    I then need to reset the cycle by holding the button for three seconds (with the door open), the water then drains out and dishwasher is ready to start again.
    Any ideas would be welcome or even a circuit diagram?
    Thanks,
    Brendon
    #343927
    Brendon
    Re: Candy CDF622 circulation problem
    Update to say I’ve fixed the problem. I replaced the main control PCB module and it works fine now. 😀
