Candy CDI 1012/B-80 Integrated dishwasher fault codes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy CDI 1012/B-80 Integrated dishwasher fault codes
  • #67127
    crockett
    Hi all,I fitted a new Candy cdi 1012/b-80 integrated dishwaswher a couple of days ago,before I left the customer I ran the machine to check than water was coming into the machine and that there were no water leaks(I stopped the machine at this stage )I also explained the programmes and controls to the customer and left.Today the customer left a message that the machine is not working and the lights are flashing.I have to call tomorrow to look at it and the lady is unavailable until then.The Problem i have is that I dont know how many or what lights are flashing and I can’t seem to find a fault code guide for this machine.It could be possible that the problem is a drain time out fault due to perhaps a kinked drain pipe(hopefully)but I would like to be armed with some faultcodes(all of them if possible) so as to have an explaination and perhaps save me another call.Iknow the machine is under warranty and i do have the 2nd faultcode guide by UKWG..Can anyone out there help me please. Regards Crockett.
    #366426
    BobHope
    Re: Candy CDI 1012/B-80 Integrated dishwasher fault codes
    PM me an email address and i will send you some info.
    Bob.
    #366427
    crockett
    Thanks Bob will do immediately,Crockett.
    #366428
    BobHope
    2 files sent as there is differant
    set ups for the same model but with differant product codes.
    Bob.
    #366429
    crockett
    Thanks very much Bob I’m waiting for them to come true I’m having a little trouble with my email I should have it sorted soon,much appreciated crockett.
    #366430
    crockett
    Thanks all for your help,I called to look at the above machine today,4 flashing lights continuously,Icould not get the machine to go into test mode (Thanks Bob for the info)decided to have a look and found water in the base tray activating the antiflood device(switch),didn’t see any obvious leaks.This machine is under warrenty and never washed a dish so I had no option but to let the warrenty people sort it out,thanks again,crockett.
    #366431
    pup
    BobHope wrote:PM me an email address and i will send you some info.
    Bob.
    hi can u pls send me info as well thanks
    electralife@hotmail.co.uk
    #366432
    crockett
    Just to let you all know out there that the retailer replaced the above dishwasher and also paid the cost of installing the new one thanks for all the help. crockett.
    Sent from my GT-S5830 using Tapatalk
    #366433
    eng14
    Hi guys,this cdi 1012 candy d/w had element o/c,complaint was obviously no heat.The d/w worked fine for a number of washes and is playing up again,leaving water inside and not cleaning ,this is the reported fault by customer.got to c it tomorrow,richard. 🙁
