candy CDI 1012 DISHWASHER
Home Forums Public Support Forums Help And Support Dishwasher Help Forum candy CDI 1012 DISHWASHER
  • #28198
    lesleykay
    mY DISHWASHER KEEPS PUMPING OUT AND WILL NOT RUN ANY OF THE PROGRAMS. THE INDICATOR LIGHT IS BLINKING DENOTING A FAULT. IHAVE CHECKED TO SEE IF IT IS FLOODED AND THERE DOESNT SEEM TO BE A SENSOR, CAN ANYONE HELP?
    #217339
    Re: candy CDI 1012 DISHWASHER
    Is there any pattern to the flashing light?
    lesleykay
    None that I can make out
    #217341
    Hi Lesley,
    There should be a sequence to the flashing LEDs and that gives the fault code in much the same way as the Hotpoint/Indesit machines do.
    If Candy follow their normal ways then true to form if the machine abort for, well, pretty much any reason, it will drain down first then sort of sit there doing not much of anything. It should flash reasonably rapidly a number of times (the fault code) then pause and repeat.
