Candy cdi1012
  • #80963
    scottygio
    Hi Guys first time posting.
    I’m an electrician to trade but could do with some pointers on my candy cdi 1012 dishwasher. Have had it for 7 years and it has been great. Now it is not working.
    This is what happens.
    I select program, shut the door, the inlet valve works and you can here the water entering. The drain pump definitely works because I can here water getting pumped out. so water is getting in and coming out. But no water enters the washer . The spray arms don’t move, I have checked this. So it must be the main circulation pump right?
    I have checked the following:
    inlet filter is clean
    inlet valve seems to be functioning
    drain pump seems to drain
    The main circulation pump. I don’t see no capacitor so it must be a permanent magnet pump right? How do you test these?
    would appreciate any pointers in getting my dishwasher working again
    thanks
    Scott
    #414974
    scottygio
    Re: Candy cdi1012
    Definetely not the pump. took it into work ,put it on a test bench and put 230v across it. pump working fine. But why won’t the spray arms turn? A blockage perhaps?
    Scott
