candy cdi1012-80
  • #40764
    hilly
    intergrated d/w fills then the circulation pump just pulses continuosly until turned off. im assuming its pcb fault but this is the first one of these ive come across, no sign of blockages, capacitor ok,
    any ideas pls
    thanks paul
    #267461
    Re: candy cdi1012-80
    think u are right but may be fixable but have no info on this machine but this is what i would look for on this fault
    look at pcb. is there a capacitor big one about 1cm by 2 should hve a value either 1uf or 1.5uf if so this is power supply to board get them going all the time hoover t/dryers smeg dishwashers ariston and many more
    if these go down its like having low batteries has enough power to fill but turn the motor on and voltage drop you can see the logic
    they are only cheap and an easy fix if this is the case
    hope this helps
    hilly
    cheers dave ill give it a bash 😆
