Candy cdi1012/80 Error codes
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Candy cdi1012/80 Error codes
  • #73776
    coachadams
    I have a candy with error code 5 What is it I cannot find any reference to it.
    Foolishly I have replaced the NTC and the control card.
    #388759
    Re: Candy cdi1012/80 Error codes
    E5 refers to an NTC or Control Board fault so it appears you’ve got it covered. It’s one or the other OR the connections between the two!
    #388760
    coachadams
    Martin,
    Thanks for your reply. When running the factory test programm the alarm comes at the end of the cycle. As does when run a rinse cycle is this normal for this fault condition.
    #388761
    coachadams
    Sorted error 5 faulty card and cable broken.
    Later had error 8. This has now turned into track the broken cables in the door hinge point. Looks like 5 cables were damaged prior to wrapping round some sticky tape. All now repaired and functioning OK. Put the marrigolds away
