Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Candy CDI1012 Dishwasher – Module?
- This topic has 10 replies, 3 voices, and was last updated 18 years, 9 months ago by
MickGeorge.
July 4, 2007 at 4:25 pm #28721
MickGeorge
ParticipantHi Folks
Just been to above built in m/c… m/c looks dead but have supply both in and out of on/off switch and looks like it then supplies a small module.. which in turn supplies every thing else including the progam selector buttons/indicator light module.. there are no prog indicator lights lighting up..so presumably this is the small module that is faulty..
Before ordering just need to know that this m/c doesn’t just shut down if there is a fault on m/c without any indicator lights on.. (which wouldn’t suprise me these days :rolls: ).. or if anything else might be at fault eg.. prog selector module? or if anyone else had this prob… (First one of these m/c I have seen by Candy)
Mick
July 4, 2007 at 5:08 pm #219749MickGeorge
ParticipantRe: Candy CDI1012 Dishwasher – Module?
p.s. Anyone got the part no for the module.. cant find it on Connect..
Mick
July 4, 2007 at 7:06 pm #219750Penguin45
Tonights homework is in your in-box……….
July 5, 2007 at 8:22 am #219751MickGeorge
Sorry Chris… could you send me that info again as it wouldn’t open on my work computer.. it might be that I am only running Acrobat 5.01 due to Distripart Disc..
If you can send it me again then I will open on other computer which has all latestest updates on..
Mick
July 5, 2007 at 6:34 pm #219752Penguin45
Re-sent.
Chris.July 5, 2007 at 8:13 pm #219753MickGeorge
Thanks Chris – got it this time.. err have you an Italian phrase book as well?.. 😆 Only joking but not a patch on the old Hoover stuff..
Thanks again
Mick
July 11, 2007 at 4:50 pm #219754MickGeorge
Been back to this today to change module..
Ser No. rubbed of side of door due to over cleaning by cust but DOP 29/11/04 so ordered up module partno 41008097 as it pre-dates production (10/01/2006) according to sheets that Chris kindly sent me..
Part arived with partno 49007819 so presume partno change.
Went to fit today and connector pins for switch/light module ribbon cable missing.. There is a simmilar connector on the bottom edge of board which is also on the original and not used.. Didn’t want to connect it without checking first as didn’t want to risk blowing other module
Does anyone know if this is the right partno swap for the above module and if so is there a mod to it or has some one forgot to put the connector on the board?
Mick
July 11, 2007 at 11:11 pm #219755Penguin45
There appears to be a “/1” version…….. Which one have you got?
July 12, 2007 at 8:19 am #219756MickGeorge
Thanks Chris
Sorry, the only info I got is model no from front of m/c and dop from customer as all other info on sticker on m/c rubbed off due to cleaning..
If there is another info plate on m/c it will mean kitchen dismantle to find it as unit is intergrated..
There is a number on the module (151a – 41012534) but thats prob no use.. have typed the 4101… no in on Connect as it looks a bit like a partno and it does come up with a module…. but it is special order and only about £8 so I don’t think that is the right module.. no picture either..
Why do manifatures keep changing parts/numbers/models so much?.. cant be cheaper in the long run as all different parts they have to keep and all the agro/time wasting it produces.. 😡
Mick
July 13, 2007 at 1:14 pm #219757loopey
TECHNICAL NOTE N. 006 LS – 11/17/2004
SUBJECT: Totally integrated electronically controlled “Easy” range built-in
washing machines: the washing cycle hangs.
We’re experiencing on the field many unnecessary replacement of “EASY” type
electronic modules (see Note n. 004ls04 – 05/03/04). This is mainly happening
on the totally integrated appliances (I.e. CDI1012 – CDI2012 – CDI2015 –
CDI3015 – HFI3015).
The Customer complains that the washing cycle hangs up, being the cycle LED
lighted fixed. No reset operation at this point is possible.
This trouble may be mainly due to:
1. the washing cycle is not yet ended.
2. a wrong operation was carried out, to cancel the washing cycle.
1st CASE: THE WASHING CYCLE IS NOT YET ENDED.
This trouble happens often in the end phase of drying, being the machine silent.
The customers thinks the cycle is ended (since these appliances are not supplied
with an acoustic alarm) and tries to set and start a new washing cycle. Starting a
new cycle while the previous is not yet finished, may cause the machine to hang.
Being this the situation, best is to close the door and wait for the cycle to be
ended. Otherwise, reset the machine, by carefully carrying out the following
sequence of operations:
· Open the door of the dishwasher.
· Push and hold the button of the current washing cycle, for 3 seconds.
· All program’s LEDs will flash simultaneously (RAPID 32′ excluded).
· Close the door of the dishwasher and wait for the end of the phase of drain.
WARNING!
If the dishwasher’s tank is already empty from water, therefore
there’s no need to carry out a drain phase, please wait the same at
least 10 seconds, before re-opening the door.
ã 2004 2
· Re-open the door of the dishwasher.
· Now, the LED of the “favorite” washing cycle is flashing. You can confirm it,
choose a different one or switch OFF the machine.
2nd CASE: ERROR WHILE CANCELING THE CURRENT WASHING CYCLE:
The machine hangs if the previously described procedure is interrupted, by
switching the machine OFF while the program’s LEDs are flashing.
If the machine is switched OFF while the 3 program’s LEDs are flashing, once it’s
switched ON again it will be blocked: the LED of the last carried out washing
cycle will be ON fixed and no reset operation is possible.
In such a case (program’s LED is ON fixed), simply close the door of the
dishwasher and wait for 10 seconds at least, before re-opening it.
Once the door is re-opened, the only LED of the washing program which was set
at least 3 times in sequence (a favorite one) will be flashing. This means the
dishwasher is ready to carry out a new washing cycle, or to be switched OFF.
The trouble described in the present Note may be created on the correspondent
free-standing appliances too, but it’s less frequent, since on these products it’s
not necessary to open the door to look at the LEDs.
Best regards.
GIAS S.r.l.
3 MODULES ON THIS VERSION41008097 Electronic module
41016113 Electronic module
41012534 Program electronic moduleHope this helps
July 14, 2007 at 4:04 pm #219758MickGeorge
Thanks for the post Loopey..
Don’t think this is a module “hang” as I have not got any of the LED lit at all which makes me think it is main module or possibly program module as supply though on/off switch to module..
But not getting any joy atm as Connect saying it is right module.. although there is no connector for the ribbon cable as on the original.. all very confusing to say the least… 😕
But thanks for all the info..
Mick
