Candy CDIM6120PR-80 Ser32900511 1529 0061 dishwasher not heating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy CDIM6120PR-80 Ser32900511 1529 0061 dishwasher not heating
  • #98531
    Washdisher
    Only a few yrs old and quite tidy looking machine. Water pressure sufficient to whiz the spray arms round, checked both pressure switches (I know the heater one burns out on these) and element all ok, wiring and pcb visual inspection. I’m thinking temp sensor/electronics.Temp sensor reads about 23kohms ambient. Any clues please
    #472733
    from what i can see of the diagram there are 2 switches in the heater lines
    to check both at once the best way i can see is to see if you have 240v across board terminals 1 and 2 also poss label N and RS wires N is white and A is brown and should be terms of heater relay
    if you get 240 then the board is not turning heater on
    if you dont its in the pressure sw circuit
    from the temp sensor reading and the little info i found it sounds about right
    kaibart
    More than likely this change 1 or 2
