Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › candy cds120 semi int d/w 2006??? no worky
- This topic has 10 replies, 2 voices, and was last updated 14 years, 9 months ago by
gandh1.
June 15, 2011 at 4:15 pm #63390
gandh1
Participantfascia panel with on/off LHS & half load
RHS knob with 2 lights – on/off(lower) and end (upper)?first pump blocked. cleared, worked ok.
failed again, so found blockage in ubend. cleared.
test ran in shop, worked, opens dispenser, and heats, then faults about 3/4 way thru. anyway, stripped down under and cleared for all blockages, none found. got a big askoll type naff circ pump, but usually it will fill, but this wont even fill now, cant fathom it.,
any advice or diagnostic techniques appreciated!
Rich
June 15, 2011 at 6:59 pm #353627loopey
ParticipantRe: candy cds120 semi int d/w 2006??? no worky
email addy please can send you stuff
June 15, 2011 at 10:55 pm #353628gandh1
you have pm 🙂
June 16, 2011 at 2:42 pm #353629loopey
check yer inbox 🙂
June 16, 2011 at 6:52 pm #353630gandh1
3 flashes so im assuming its one of the pressure switches are done in by the clogged u bend (it was also on a spike) as its on the test rig, and tehres not a blockage to be found 😀 do you have prt nos for the p/s ? connect and qualtex dont list any for this model 🙁
June 16, 2011 at 7:11 pm #353631loopey
41009660
41016499also check the heater safty pressure stat underneath the heater
they get gunged up like the whirlpool dishwashers , that will stop it dead in its trackshth phil
June 16, 2011 at 8:16 pm #353632gandh1
cheers phil, ill look tomorrow before processing order, thats poss whats happened to this as it worked till 3/4 way thru here, but it might be that its just a bit too gunked.
June 18, 2011 at 10:45 pm #353633gandh1
managed to find and unscrew, nothing holding it down, it clicks ok and shows a break in current when depressed too. so assuming its ok, so looks like p/s ???
June 24, 2011 at 12:00 pm #353634gandh1
ok still no joy with new p/s…
module looks fine, and very basic, cant see why that would fail, elements ok, pumps alright, circ motor seems ok.
completely baffled with this now !?!
any other ideas before i condemn this poorly built badly specced piece of tin to scrapyard in the sky ?
PS does anyone have a module part no for it so i can quote a price to cust…
ALSO one last thing, it seems to hesitate for 10 seconds before flashing the top led, on the last programme and the first 3, the other lowerr 4 progs it flashes a failure instantly… ???
June 24, 2011 at 7:41 pm #353635loopey
showing 2 pcbs part numbers 41008104
41016094
ok has the fill valve have a pressure hose type pipe to it ? these can get airlocked with a drop of water especially when moved will stop it filling with water ,
hth philJune 25, 2011 at 3:26 am #353636gandh1
phil the faults happening will have been down to the ubend being completely gunked up, i cant think of anything other than that being the sole reason for dw not to start a wash…
