candy ce10 washer dryer
  • #13739
    robbo1973
    hi just been to this machine with a strange fault never came fault across before. Any cycle selected the machine continously pumps out and tumbles and that is about it valves ok pressure switches seem ok. Has anybody had this prob before going to have a proper look at it tomorrow in the workshop a little headstart would b nice. 😉
    #156400
    Dave_Conway
    Re: candy ce10 washer dryer
    Can you get the product code beginning 3…… from inside the door ?
    I’ll check the tech info then.
    Welcome to the site by the way 😀
    #156401
    robbo1973
    numbers are 31116007 9927 4261 thanx.
    #156402
    Dave_Conway
    Hmm, odd one. I was expecting to see an electronic controlled washer but it’s a standard mechanical timer 😕
    Personally I’d go with the pressure switch theory, the module only appears to be a motor control unit. Aprt from that, the timer may be the problem.
