Candy CE101
  • #32199
    allan
    Hi all, help please. Had to go to this Candy mod. CE101 with no spin, Motor brushes worn out replaced with gen hvr and tested all fine, customer phoned next day to say that it had done one wash and had stopped spinning again, checked module and saw over heated joint on one of the relays, tried resoldering but no use, fitted new module still no spin, checked motor again and found that if you moved one of the wires going to the tacho (right as it enters tacho body), meter showed open circuit could this cause no spin? or am I missing something else
    Thanks Allan
    #234060
    Re: Candy CE101
    Nope, tacho failure will let the pcb do one kick and then it all shuts down.
    Motor 91200826 required.
