candy cfd 612-80 error code
Home Forums Public Support Forums Help And Support Dishwasher Help Forum candy cfd 612-80 error code
  • #46665
    linrew
    hi,
    candy CFD612-80
    320003360726 0902
    GIAS01/P21
    any ideas what the wash light and rinse light comming on and the alarm sounding all at the same time is indicating,
    its been way to long since i worked on these so i have forgotten 😕
    many thanks
    linrew
    #290449
    Re: candy cfd 612-80 error code
    Is that lamps 1 + 3?
    linrew
    hi
    it is lamps 2 and 3
    thank you
    #290451
    It’s a Chinese one – the lights lit do not match any known error code. Standard faults on these are heater circuit and water level problems – this one uses a flow meter rather than a pressure switch.
    Failing that, the pcb has corrupted if you cannot reset it.
    linrew
    hi
    many thanks for the reply
    the machine appears to be filling fine and then heating all ok
    i will look into it further and ask if i need more advise
    thank you for your quick response
    linrew
    #290453
    linrew
    hi
    i have ran this machine a couple of times over the weekend and it now appears to go through most of the wash (fills, heats,washes and rinses) the gets near the end and light 2 (wash) flashes the alarm sounds and the machine empties for 2 mins then stops
    any ideas please as its a very very long time since i worked on candy
    i know it will be something stupid that i am missing
    linrew
