Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › candy cic60 clean filter light on.
- This topic has 9 replies, 6 voices, and was last updated 21 years, 6 months ago by
simllfixit.
October 2, 2004 at 5:04 pm #6393
simllfixit
ParticipantHi, can any body help me with this one? the light stays on after filter has been cleaned and replaced. would be very greatfull of any assistance as im going to go and look at it soon.
thanks Simeon.
October 2, 2004 at 5:56 pm #117427BobHope
ParticipantRe: candy cic60 clean filter light on.
Is the appliance still working ok ?
i bet it has no heat due to the microtemp fuse in the heater being O/C.
Cheers Bob
October 2, 2004 at 6:21 pm #117428simllfixit
thanks for your reply, i will have to find out tomorrow as im only going from an answerfone message i was left. cheers Simeon
October 8, 2004 at 4:37 pm #117429Cleat
Most certainly is microtemp fuse.. we have done 3 in as many weeks.. think its 152oC but will check…
October 8, 2004 at 9:08 pm #117430Dave_Conway
Yep, definite the thermal fuse o/c.
Cleat will supply the correct temperature replacement hopefully, I can’t recall what it is either 😕
October 8, 2004 at 11:07 pm #117431steve57
hi
repaired one today put in a new the thermal fuse ,fault cured,regards
steveOctober 13, 2004 at 1:42 pm #117432Cleat
Yeah my memory did serve me correctly.. it is 152oC ….
October 18, 2004 at 11:20 am #117433Cleat
We have another doing same…lol.. But keeps re-blowing thermal fuse after about 5mins,, so gonna try the Blue spot TOC inside the element… but connections show only a complete Element… Any one know part number for blue spot stat ?… Thanks..
October 18, 2004 at 2:59 pm #117434Martin
Cleat wrote:keeps re-blowing thermal fuse after about 5mins
Sorry Cleat no idea of the value of the TOC on the element itself 🙁
But HOLD UP for a minute, you say it keeps blowing the Microtemp ❓ Then it must be getting bl**dy hot around there ❗ Have you checked the fan chamber, condensor and ducting is giving good air flow to the element in the first place ❓
I would suspect an air flow problem you got there mate 🙂
October 19, 2004 at 12:03 pm #117435Cleat
All airways clean and free 😥 ….. Toc was cheaper option than element complete.. toc maybe not cutting out.. just blowing thermal cutout ?? 💡
