Candy CM1 146 Will only pump on any programme
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy CM1 146 Will only pump on any programme
  • #56594
    neilsukwg
    Candy CM1 146
    This machine will only pump
    No matter which programme is selected, the machine selects the 15 minute
    cycle and pumps for a couple of minutes before switching off.
    No fault codes displayed
    Its about 2 years old and used every day, checked carbs, blew pressure switch etc.
    Any ideas?
    Neil
    #328067
    suedehead1
    Re: Candy CM1 146 Will only pump on any programme
    could be the selector switch or pcb.
    #328068
    SimonCD
    i have had one of these where the selector switch had come apart inside, i reckon it will be that, it is actually quite easy to take selector apart and it will be quite obvious if its faulty.
