Candy CMD146-80 – No action
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy CMD146-80 – No action
  • #63602
    OLLIE2806
    Hi guys,
    Select a prog and turn the above machine on, the door locks and nothing, It just sits there, I have found the dryer side or the valve is open circuit & the brushes are quite worn (not drastically though). Is there anything else i should be checking for?
    Thanks in advance
    Ollie.
    #354276
    loopey
    Re: Candy CMD146-80 – No action
    front option buttons stuck in ? ,Motorized selector motor o/c
    dry joint on pcb , also check the large 1,5uf cap on pcb can cause this , can get dry joints there its the one with a pile of glue next to it ,
    hth phil
