Candy CN100T Auto W/M – Rotating Timer knob
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy CN100T Auto W/M – Rotating Timer knob
  • #22964
    MickGeorge
    Went to this today to fit door gasket – fitted door gasket and then cust says “Oh by the way” as they do “used machine and the last twice the timer knob starts to rotate halfway through programe… Tested machine and timer knob starts rotating after first rinse and spin..
    Check machine on last rinse and spin – works ok..
    Questions..
    Does the timer knob rotating on these machines indicate a self diagnostic fault or is there something wrong with selector switch (slave unit?) or module to cause this type of fault? If so which one likely to be cause?
    If it is a self diagnostic fault any ideas as the pump, motor, water valves and pressure system all seem ok?
    Thanks folks..
    Been 30 years in the trade but the way they keep changing machines these days I feel like an amature 😥 It seems harder to keep up with where manifactures are coming from these days :rolls:
    Mick
    #196648
    Re: Candy CN100T Auto W/M – Rotating Timer knob
    These Hoover/Candy selector switches often do this. A new one is only about £13 + at MPt, or dismantle old one and clean the contacts/slider board with carbon tet or alcohol. Usually works, otherwise board to emw for repair.
    Mike.
    #196649
    MickGeorge
    Thanks Mike
    Will try timer first then..
    Mick
