Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Candy CN136 Washing machine bearings – 31000753044322215
- This topic has 7 replies, 4 voices, and was last updated 19 years, 8 months ago by
RocketMan.
July 25, 2006 at 11:46 am #19420
RocketMan
ParticipantHi,
Anyone got part numbers and best source bearing for above machine. Bearing worn, not too badly yet and told customer not to use.
Thanks in advance.
Rocketman 8)
July 25, 2006 at 12:34 pm #183030Dave_Conway
ParticipantRe: Candy CN136 Washing machine bearings – 31000753044322215
Bearing seal part number 92445600
The inner bearing is 92440171 and the rear 92440197 (6204ZZ). I can’t find the size for the inner but my guess would be a 6205ZZ 😉
Candy prices are about a tenner each for the bearings so you could get a 6206ZZ just in case as well for less than that 😉
July 25, 2006 at 10:08 pm #183031aqualectric
I did one of these about a year ago now – used a Zanussi small bearing kit. 6204ZZ and 6205ZZ bearings and the seal is identical. Fitted and worked a treat. 😉
Hope that helps as I had exactly the same problem finding the individual parts; so I eventually stripped the machine and matched the parts.
Steve.
July 25, 2006 at 10:55 pm #183032RocketMan
Steve,
thanks for that. I thought it was just me having difficulty getting the parts.
Even Gias didn’t have them in. Have ordered all three bearing but will try and cancel the 6206zz. At least now it’s logged here for anyone else when they do a search. Going to get the machine into the workshop tomorrow and strip it down and hopefully fix Thursday.Thanks again.
Rocketman 😀 😀
July 25, 2006 at 11:10 pm #183033aqualectric
Make sure you have a winch or 2 people available when you come to lift out the drum – ‘out through the top’ job. The drum is a cumbersome and heavy assembly to handle alone. 😉
Steve.
July 25, 2006 at 11:14 pm #183034Penguin45
Personally, I drop the motor and tip the machine on its side – it’ll slide out without too much bother.
July 26, 2006 at 9:16 am #183035RocketMan
Thanks again guys. Yes normally do it 2 man lift but working by myself. Getting back to the workshop so can use some form hoist. If that doesn’t work I’ll try on the side as suggested.
thanks
Rocketman 😀 😀July 30, 2006 at 1:57 pm #183036RocketMan
Thanks aqualectric, you were right, 6204 & 6205 bearings. Easy enough one man job when top weight and motor taken off, bottom weight dropped (gently) into the bottom. Only problem was customer continued to use it (despite being told not to) and drum shaft is not in too good a condition and not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure water seal will be good enough now, we’ll wait and see. Thanks again to all 4 the help.
Rocketman😀 😀 😀 😀 😀 😀 😀
