Hi all,
My first post here. Must admit that the title is no longer true: I managed to open the door by unscrewing the top and forcing it to open manually.
I need some help now as to know which of the parts are faulty:
so much force on the handle was applied that it has a crack. How would you know if the problem comes from the door lock within the machine or the interlock?
Any idea?
Best to have a look at the door lock first and see what the score is there. If you need the lock just drop Dave a not on spares@ukwhitegoods.co.uk and he’ll tell you which one it is.
Hi Kwatt,
Thanks for your quick response. I’ve had a closer look at the door handle and I think I ought to buy not only a handle but a whole kit with the latch and latch plate as the latter seems broken.
I am contacting Dave to find the relevant parts.
A.
