Re: candy combiwash ce124
What you should say is that it will not empty or spin, most machines will not go into spin if they cannot empty.
Is there a filter behind a small door or the kickstrip at the bottom on the front of your washer. If so the first thing to do is to make sure that is clear.
Try and lower the drain hose into a bowl, if the water does not flow out freely you will have a blockage somewhere.
If you cannot hear the pump running, it may be jammed by a foreign body, could also be a faulty pump.
