candy cond t/drier, not starting. CDE105 80
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries candy cond t/drier, not starting. CDE105 80
  • #36009
    TELL
    have checked the m/c for power, there is 240v going to the module, and switches etc, checked the display board its ok. can anyboby confirm, is it the module. had a look for bad joints, or anything blown, nowt to be seen.
    1st one ive been to, and can’t see any thermal cut out etc.
    TELL..
    #249129
    helo_75
    check the float switch, have you?
    #249130
    Flyman
    Re: candy cond t/drier, not starting. CDE105 80
    Hello Terry. Thermal fuse is mounted inside the element at one side.
    #249131
    TELL
    checked float switch, but there is no power, or lights on the display board, or indication of tank to be emptied ?.
    hi jim.
    never checked the element toc, did not know their was one, but would this shut down display, and functions on all of the drier. as i said i have 240v coming into the module, and power to door m/switch.
    #249132
    helo_75
    is that the model where the start button breaks behind the bezel?
    try taking the board off, and check where the button activates the pcb?>
    #249133
    TELL
    i have taken off the display board and cheked the start switch, and button they are ok. metered the switchs and i’m getting a reading through them.
    TELL..
