I’m trying to fix the above and struggling a bit.
It does dry the clothes but makes the workshop floor wet instead.
The leak is coming from the back in the general area where the bottle plugs in to the valve.
I have removed the valve and it’s clear, also made sure the small hole that leads from the condenser housing to the valve is clear anbd that the mating surface between the condenser and the rear of it’s housing is clean.
I am reluctant to strip it down far enough to get to the “holding tank” (if that’s what it’s called) in case I’m missing something obvious.
Any ideas gents?
