candy cpc240ff problems.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum candy cpc240ff problems.
  • #17824
    woddy
    Can anybody help me. My fridge freezer has gone on the blink. The symptoms are:-
    it isn’t getting cold.
    the compressor is getting warm and when I put it on the coldest setting, the fan in the freezer stays on.
    The stuff I’ve had to eat!!
    the serial numbers are model cpc240ff, NLY13k, R600a.
    I believe this model doesn’t have a thermostat, it is all controlled from the central module. If it is this does anyone know where I can get a cheap one.
    cheers you guys! 😯
    #176535
    Dave_Conway
    Re: candy cpc240ff problems.
    woddy wrote:the compressor is getting warm
    Check that the compressor is running constantly, if it is then it’s likely it’s a system problem (compresor failing or refrigerant shortage).
    #176536
    woddy
    Yeah it is running all the time.
    Looks like I’ll have to get someone in.
    Cheers for that dave, much appreciated.
    #176537
    jimbob20uk
    can you pull out draws to freezer and make sure that at the back of the freezer isnt iced up, and is the fridge working or not
