Candy CPC290FFK Fridge freezer,
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy CPC290FFK Fridge freezer,
  • #6573
    Owain84
    Hello fridge keeps freezing, changed the module but it was a faulty one so have to order a new one…. How on earth do you get to the sensor to change that as its somewhere in all the foam in the back.
    Is it ever the sensor or is it always the PCB?
    Cheers
    Owain
    #118398
    BobHope
    Re: Candy CPC290FFK Fridge freezer,
    Hi Owain
    I have had quite a few sensors go short circuit in these candy appliances causing the compressor to run constantly. take a resistance mesurement on the fridge sensor from the module plug to see if it has gone S/C.
    to replace it is not as hard as you think but take the mesurement before you proceed.
    Cheers Bob.
    #118399
    Owain84
    what should the resistance be on the sensor and how do u get it out? I’ve had a little dig in the back of the fridge but didnt want to go ne further incase of damage
    #118400
    BobHope
    hi
    the approx resistance depends on the temp of the fridge sensor,
    -30c abt 47,000 ohms
    0c abt 9,000 ohms
    +20c abt 3.500 ohms
    if the module is ok and the reading is below 3,500 ohms then measure
    6.5 inches down from the top and 6.5 inches in from the left hand side looking from the rear of the appliance, make a 4 x 4 inch square cut into the backwall and carefully remove the insulation you will soon find it, its hidden behind an aluminuim plate and just slides in from the left.
    Cheers Bob.
