Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › candy cpca240ffk
- This topic has 17 replies, 8 voices, and was last updated 17 years, 9 months ago by
robbo1973.
July 7, 2008 at 6:02 pm #37938
robbo1973
Participantthis machine i freezing in fridge and green and orange lights flashing changed module bit still the same does any one know the resistance of the sensor or could it be a faulty module changed loads of these with no problems.
cheers chrisJuly 8, 2008 at 8:51 pm #257188davebaron
ParticipantRe: candy cpca240ffk
i had the same problem a few weeks ago ended having to change the cut out behind the insulation,if you send me your email i will send you some info .d
July 9, 2008 at 6:19 pm #257189robbo1973
ParticipantJuly 10, 2008 at 5:45 pm #257190davebaron
SOME THING SCARY IN YOUR INBOX
August 18, 2008 at 1:26 pm #257191grazzamongrel
hi i am having the same problem i have replaced a module but still have the same fault of fridge frezzing things. i have been told by customer who called out hoover/candy after me and the engineer knew straight away the fault was a probe and cut away at insulation. Can you help me with the location of probe and any other info that would help like resistance that i should get for the probe at the module end. regards graham. my email address is agmservices@btinternet.com
August 18, 2008 at 4:31 pm #257192helo_75
Participanti think if hes cut away at the insulation to get at the sensor, and refoamed, it would be easy to spot were it is, wouldnt it?
August 18, 2008 at 5:00 pm #257193grazzamongrel
the customer i went to and replaced the module wont let me back in the house because i replaced the module which didnt fix the fault so he called hoover/candy engineers out and effectively paid for the job twice.and have another fridge/freezer with exactly the same fault which i now know how to fix with a little help.i need to know where the probe is located and resistance of it at module so i can double check it there.
August 18, 2008 at 5:03 pm #257194grazzamongrel
davebaron wrote:i had the same problem a few weeks ago ended having to change the cut out behind the insulation,if you send me your email i will send you some info .d
please could you send me some info on fixing probe problem, if you know where to cut insulation that would be great and how to re foam or can bit cut out just be “stuck” back on?
August 18, 2008 at 5:49 pm #257195Penguin45
File in your in-box.
January 5, 2009 at 6:56 pm #257196spanner51
I have the same problem with this model. freezing in the fridge, and the yellow super light flashing. I think a new NTC would cure the problem. I would be very gratefull for the info on changing it.
thanks
Graham
January 5, 2009 at 7:07 pm #257197subs
Hi Graham
I think you will find the instructions, with pictures, comes with the replacement NTC!
Subs
January 5, 2009 at 8:16 pm #257198spanner51
Cheers Subs
January 13, 2009 at 8:30 am #257199spanner51
Received the part yesterday p/n 97061619. but there wasn’t any technical info with it. If any one can help with some I’d be gratefull
Graham
January 13, 2009 at 8:52 pm #257200Penguin45
Sent.
January 14, 2009 at 12:26 pm #257201spanner51
Thanks Chris
Just what I wanted (I think)
Graham -
