Candy CS 455 Stuck on Cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Candy CS 455 Stuck on Cycle
  • #20741
    Lionpops
    help… my candy CS 455 dishwasher is stuck on emptying and the cycle wont move on even when I move it to another programme. I’ve unplugged the machine to try and clear it but it’s not worked. The machine just keeps pumping even though there is no water left in it.
    #188213
    Re: Candy CS 455 Stuck on Cycle
    Flood protection is activated – the tray under the machine is full of water. Unplug and lean it back to drain the water. System will then reset. However, if you don’t find the source of the leak, it may well recur.
    Click the link below for a UKW engineer in your area if you are unsure how to proceed.
    Power off if you are investigating.
    Lionpops
    Thank you – my machine is up and running again!!! Tipped it backwards, mopped up floor and all OK now! :0)
    #188215
    matkins
    Problem is still likely to re-occur until the source of leak is found, strongly suggest further investigation to prevent problem becoming worse.
