Candy CS455M not heating
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Candy CS455M not heating
  • #71919
    xdxmabo
    Candy CS455M not heating up.
    I replaced the heating element 2 months ago and it seemed to go faulty again a few days ago(not heating at all)
    I took the element out but it seems ok- measures 32 Ohms, the same as a new one.
    Is there a relay to operate the heater and if so where is it?
    Or is there another fault that can stop it heating up?
    I have checked the connections to the heater, all ok.
    #382797
    Re: Candy CS455M not heating
    Nope, there’s no relays but one of the thermostats will control it.
    xdxmabo
    Thanks, I replaced the thermostat today and it is now working again.
    #382799
    xdxmabo
    Unfortunately the new thermostat has now gone open-circuit.
    This is a non-resetting thermostat, so it must be overheating.
    Any suggestions why please?
    #382800
    The control thermostat or a blockage perhaps.
    semaj15
    Hi, Hope you have sorted your machine out. I have just purchased a new heater element but not sure where it is located in this machine. Any suggestions before I begin to pull it apart.? Thanks
    #382802
    How do you know that’s the fault then if you don’t even know where the heater is?
    It is located in the base.
