candy csd69 s
  • #85446
    mikehha
    good morning
    just a quick one for all you candy/hoover engineers.Do you have to program part no 49020082 or are they pre programed as the one I have just fitted dose a prewash and nothing else and you cant select another program.
    #428639
    Jackal
    Re: candy csd69 s
    That module is pre programmed.
    There are two different ones fitted depending on serial number though, if the serial number is 0949 or above then you have the correct one, if it’s below the part number is 49017948.
    #428640
    mikehha
    Re: candy csd69 s
    Maney thanks for the quick reply . mike
