Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Candy CSE C10LF 10KG
- This topic has 6 replies, 3 voices, and was last updated 3 years, 2 months ago by
Shroppyfly.
January 13, 2023 at 5:37 pm #101599
Shroppyfly
ParticipantHi Experts,
My last lazy start query im living with lol, but here’s another thing I’m stuck with, i had the above dryer, and i’ve had it that long i can’t actually remember what was wrong with it, except to say im really struggling to refit a belt to it— And i know that’s an easy problem BTW the dryer worked A1 before i thought changing the belt would be a good idea , and yes id agree usually but heh , hands like shovels,
Anyway today I was gifted the identical dryer, whether by luck , or someones taunting me, the guy said its stuck on pause, so he’d read its the door interlock, so he replaced it , but still the start/pause button flashing, So I thought ahaaaa, ill swop over the top panel with buttons and board and happy days,Mmmm so i swapped them over and ( i know this panels fine ) still the same fault:confused::confused::confused:,
So, a hard question? where should i look for the fault, stats or start capacitor??? or is there a test/service programme for this modelThanks guys and lady experts
JamesJanuary 14, 2023 at 12:16 am #485358electrofix
Moderatorif the start capacitor has gone then it should not stay on pause and giving the drum a push should make it run
January 14, 2023 at 6:54 am #485359kaibart
ModeratorMaybe the facia panel as the touch control goes through that
January 14, 2023 at 7:46 am #485360Shroppyfly
Participantelectrofix wrote: if the start capacitor has gone then it should not stay on pause and giving the drum a push should make it run
Dave id agree, esp as Ive swopped the complete front panel for one I KNOW is good, so by pressing the start” touch button” that should go green and then give the drum a helping spin , but Nowtttt……., these capacitors are a pain, does the helping hand method only work when the capacitor is Fail— ing IE on its way out, if it completely dead– would the helping hand method still work? I mean what would happen if the capacitor wasn’t connected up , then the light wouldn’t go green OR would it, and the helping spin of the drum wouldn’t work , am i understanding it correctly ?
January 14, 2023 at 7:47 am #485361Shroppyfly
Participantkaibart wrote:Maybe the facia panel as the touch control goes through that
Thanks Kai , but ive changed the Fascia panel for one I KNOW is good
January 14, 2023 at 8:46 am #485362Shroppyfly
ParticipantSo 8-40 am, after wiggling all the electrical connectors and swearing a bit , its fired up, so just letting it run to test the heater and condenser, will give another update later , im semi happy
January 21, 2023 at 6:19 pm #485363Shroppyfly
ParticipantFinal update, that seems to have done trick cheers kai
