This candy dishwasher is not heating the water , I’ve had module checked by EMW
I’ve checked all wiring also pressure switch . There’s full mains voltage sat on one side of the element but no neutral , The only other thing I can think of is to try replacing the thermistor just wondered if anyone has any experience of these machines.Thanks for help.Larry.
Did you check if the wash pump impellor isn’t blocked with stuff? I have gone to a few Candy’s with this problem. If it is blocked it can reduce pressure and might not activate the pressure switch, that’s if it is the same set up as the 1012..
