1st time to one of these dishwashers.
Fills to operating level ok (I presume) and stops filling then motor comes
in for fraction of second – stops, machine begins to fill again – stops filling,
motor comes in for fraction of second – stops, machine begins to fill…..
and so this cycle continues until the pump comes on and empties some
water out.
Then the fill/stop cycle begins again until pump comes in again.
There are two pressure switches and I assume that the normal level
pressure switch is switching the water on and off and is faulty.
The second PS I assume is the level safety switch and is doing its business
of emptying out the water due to this fault condition.
Can anyone confirm this please and if I need the `normal fill` pressure
switch I would appreciate a part number.
Many thanks.
Laurence
