The oven is labelled as a DF231 although I believe that this may now be known as the FDP231. The fan has stopped rotating so I presume it’s time for either a new motor or new oven. Can you please let me know how much a new fan motor would be? Thanks
Re: Candy DF231 ( FDP231 ?) double oven – fan motor required
The Serial number seems to be 44 1 00041.
I know that this doesn’t begin with a 3 but it’s the only number I can find (from a stuck on plate at the bottom of the oven door)!
The only other number I can find is that the ‘Installation and Operational Instruction Book’ I have is dated August 1996 with Part No 481900001 (just in case this helps to clarify anything!)
