Candy DFI 50
  • #52834
    jimluxe
    Why do mates machines give the most problems?
    The machine over fills and the anti flood kicks in and
    The machine goes dead
    On the bowel are two pressure pipes one to the
    Solenoid and one to the pressure switch when the
    P switch is activated that’s when it stops.
    What I need to know is what activates the normal wash level.
    Maybe I cant see the wood for the trees.
    Any help would be appreciated
    #313322
    Re: Candy DFI 50
    Machine should stop filling when the pressure switch is activated. The secondary hose to the valve operates a pneumatic shut-off.
    Possible problems are water in the pressure hose/switch, or the air collecting chamber is full of crud.
