Candy DFi45 Dishwasher
  • #96880
    WhiteVanMan1
    Dishwasher drains and fills as normal, then kicks into circulation mode. After about a minute or so, it stops for about three seconds, bleeps twice, and then kicks into circulation mode again. It repeats this pattern until switched off. I suspect a possible heater/PCB fault. Door harness is undamaged. Any ideas please? Cheers. Steve.
    #465172
    well I have an idea what this might be
    I Think you are correct its a board problem board part no 91942183
    but I also think I know what is wrong with the board but to be able to certain I need to see the board outside its plastic box from both sides
    if you want to post some pics then I can have a look
    best way is to post pics offsite and post links to them as site has size limitations
