candy dishwasher a8001
  • #44112
    suedehead1
    hi,
    the machine is not heating the heater is ok and so is the thermostat and thermistor.
    i changed the pcb 49003171 and there was a tech info sheet explaining to set it up for dishwasher with “water heating element in tank” or with “external water heating”.
    but i dont really know what difference it would make if i did it wrong.
    the bulletin is in pigeon english.
    thanks in advance.
    #279811
    Re: candy dishwasher a8001
    I would be inclined to think that you must have taken the wrong option and it’s worth re-setting(?) and trying it the other way. If it thinks it’s going to be fed with hot water then it’s probably not going to turn on its heater.
    Mike.
    #279812
    Internal heater is the floor mounted one. External heater is the one in the up-pipe to the top rotor. Both have safety thermostats in circuit…..
    suedehead1
    the heater is visible in the inside of the tank under the lower basket.
    #279814
    suedehead1
    i tried it both ways and it still doesnt heat i have told the customer to call candy.
