Candy Dishwasher CDI 1012/2-80
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Candy Dishwasher CDI 1012/2-80
  • #74419
    tomch
    Problem: When switched on all 5 LEDs flash and bleep, then 4 LEDs continue to flash and bleep until the door is shut the washer then runs for about a minute and stops…Whats the problem/answer
    #391497
    Partswizard
    Re: Candy Dishwasher CDI 1012/2-80 – check pump is not block
    It could be a blocked pump – remove the pipe to see inside the pump.
    #391498
    Miniman
    I have exactly the same issue. Can you confirm if it was a blockage to the drain pump or did you replace the drain pump. Or was it the dreaded PCB?
