Does anyone have the fault codes for this model? It has 5 LED’s and the first two are flashing. All the fault codes listed in Ken’s ‘bible’ and in previous posts found for this model make reference to the number of times the LED’s flash but this version uses the five LED’s. I have discovered that four lights flashing is the anti flood switch when I triggered it.
Its production number is 32900140.
It looks like the flow meter has to be bought as part of the water matrix ie the ‘metering unit’ unless anyone knows any different. Everything else did seem to test ok on this machine.
