Hi all,
This machine heats up to exactly 65 degrees on the main wash, drains and then fills on rinse perfectly ok every time. On the first (cold) rinse it then starts to heat up, drains, fills up on final hot rinse, when the heater switches on and off maintaining the temp anywhere between 42 and 45 degrees, or it can get to 65 degrees, and runs for an hour to an hour and a half and then aborts the programme without draining. Is there anything other than the pcb that this could be, seeing as the main wash works fine?
Geoff
