Candy dishwasher Mod.CDW 254/1UK (32143133)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Candy dishwasher Mod.CDW 254/1UK (32143133)
  • #59256
    Ashby
    Hi, Just replaced wash pump on this machine for a newer version, plastic body, electronic?
    No instructions as for wiring?
    There is 2 blue leads in one connector and one blue lead in another that came off the old one.
    A lead with 2 brown wires has been supplied with the new one.
    I’ve tried connecting them but the motor does not seem to run properly?
    Anyone familiar with this machine?
    Many thanks.
    Ashby
    #337491
    loopey
    Re: Candy dishwasher Mod.CDW 254/1UK (32143133)
    Use the wiring P/N. 41030033 (included in the Service Pack) to electrically connect the new
    “Brushless” Motor Pump to the original wiring of the Dishwasher.
    Should the new “Brushless” Motor Pump be used to replace one of the older two-speed Motor Pumps
    P/N. 91200521, you must inform the Customer how the use of the HPS function is no longer
    necessary, since the new “Brushless” Motor Pump will always work at the maximum speed, therefore
    assuring the best washing results in any washing program. For the replacement, proceed as follows:
    • Remove the old Motor Pump and disconnect it from the wiring of the Dishwasher (See Picture 1).
    Fit in its place the new “Brushless” Motor Pump P/N. 41029304 (included in Service Pack).
    • Extract the double brown wire from the three-ways connector of the original wiring of the
    Dishwasher (See Picture 2).
    • Fit AMP Terminal Cover P/N. 41011375 (included in the Service Pack) on the AMP connector of
    the double brown wire. Fit both AMP connectors of the double brown wire and of the blue wire
    inside the connector of the wiring P/N. 41030033 (included in the Service Pack – See Picture 3).
    • Connect the wiring to the new Motor Pump The connector of the wiring from which the double
    brown wire was taken and the ground wire of the old Motor Pump, remain disconnected. Please
    insulate and adequately fasten them to the wiring, with a nylon zip-tie. Test the Dishwasher.
    Unlike the similar “Brushless” Motor Pumps originally mounted on the production line, this spare
    “Brushless” Motor Pump can be bench tested by feeding it directly with 230V/50Hz, for the
    maximum time of 3 seconds. A longer time may permanently damage the Motor Pump. When not
    working, it’s possible to check the continuity of its three safety fuses, directly fitted onto the
    printed circuit of the electronic card (See Picture 4). These fuses cannot be repaired. Should one or
    more should show a lack of continuity, it’s the confirmation that the Motor Pump must be replaced
    iff any fuses have gone its a new pcb aswell 🙁
    have sent pdf to your email addy
