Candy Dishwasher not turning on…voltage drop?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Candy Dishwasher not turning on…voltage drop?
  • #86498
    hubbabubba91
    Hi everyone. This is my first post so bare with me.
    Candy C4100 W, with old style mechanical timer.
    So my aunts dishwasher stopped working a few years ago but she never got round to calling someone out to fix it. I decided to have a look. First check was obviously to see if it was plugged in, and then tried to turn it on. Nothing. Tried a lamp in the same socket and it works.
    Witht the washer unplugged, next I tried checking the main switch and door mech, and door switch with a multimeter- continuity test. All good.
    Then did a voltage test (washer plugged in) and checked the voltage at the ends of the wires that lead to the main switch. Normally would expect this to come to 230V right? It read 55V. Is it possible there is loose connection somewhere before the switch? Or damaged wires in the wiring harness (maybe mice chewing away- had mice at one point) causing a voltage drop? Could this have caused more damage elsewhere? Connections on some components are a bit black.
    Any help would be amazing. Thanks.
    #431918
    Andy jones
    Re: Candy Dishwasher not turning on…voltage drop?
    Is t a moulded plug ? Worth putting a new one on to try
    #431919
    hubbabubba91
    Yes it is. Might be worth a try. Maybe possibly check the voltage where wires enter machine first?? Might save changing plug?
    #431920
    Andy jones
    Sorry assumed you had done that
    #431921
    hubbabubba91
    🙂 bit of a faf to take it out, but I’ll do just that when I’m round there next time.
