Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Candy Dishwasher tripping the RCCB Switch
- This topic has 3 replies, 2 voices, and was last updated 8 years, 10 months ago by
chris_p.
May 22, 2017 at 5:24 pm #91303
chris_p
ParticipantHello everyone, I do hope you can help me resolve this problem.
Firstly it is a Candy CDI 1012/B Dishwasher.
It was on this morning as per usual and at some point it tripped the breaker. It can be plugged in at the mains with no issues but as soon as I switch on the power at the door controls it trips the switch.
Can anyone give me some help on where to start looking? I have checked the door seal and that seems ok so probably not the pcb. What else should I be checking?
Many thanks for your help.
Chris
May 22, 2017 at 9:29 pm #447693kaibart
ModeratorRe: Candy Dishwasher tripping the RCCB Switch
There are 3 main components which normally cause this problem 1 a mains filter where the lead enters the machine, 2 the heating element, 3 the wash pump motor.
But I would check if the dishwasher has a leak 1stMay 23, 2017 at 7:38 am #447694chris_p
ParticipantRe: Candy Dishwasher tripping the RCCB Switch
Thanks for the reply.
I’m going to have a look at it today and will let you know how I get on.
May 23, 2017 at 12:52 pm #447695chris_p
Well, spent quite a while on the internet this morning trying to find a service manual for the candy dishwasher, I did find one but it was rather bad so gave up on that.
Pulled the dishwasher out and there was signs of water from underneath so tipped it backwards 45 degrees and water a plenty came out. I presume the anti flood float switch operated correctly and the water in the bottom was obviously causing the short and tripping the switch. I removed the side panels and the back bottom panel etc and mopped up all the water from underneath, the dishwasher was disconnected at this point :death: I then had a good look underneath and it looked to me like the heater flow through pipe had come completely away so I guess this was the problem. Anyway, reconnected it and got a hairdryer on the bottom area to dry things out.
After some time drying the components out I was able to turn on the machine and select a program without the mains tripping so that was nice 🙂
Loaded the bad boy up and selected an eco wash cycle with the sides still away from the washer as I wanted to check for any leaks … seems fine so far about half way through the cycle … hopefully it will get through without any incident.
