This machine has been moved and would not work afterwards ( alledgedly). They did say it was moved very carefully and it shows no signs of rough handling.
Moved from kitchen into large cellar.
The pump, dryer fan, dryer heater and timer motor all work but there is no fill or main motor action, the large resistor on the PCB is getting warm so power to board.
Blowing up the pressure switch has no effect either.
I looked everywhere for a loose wire etc but could see nothing.
I have just downloaded the wiring diagram but wondered if there may be a known cause of this fault, I’m guessing an O/C return from valves & motor somewhere. 😕
