candy dryer
  • #50723
    superspin
    hi all
    i have to fit new belt to this dryer candy condenser cdc266 looks like a major strip down, or is there a short cut ?
    any one done one.
    #305741
    Re: candy dryer
    Front off, tub out – you’ll love it. Charge for an hour and a half if this is your first one…..
    aqualectric
    Re: candy dryer
    Penguin45 wrote:Front off, tub out – you’ll love it. Charge for an hour and a half if this is your first one…..
    As Chris says, You’ll love it…..in a purely “character – building” sense……….:snig:
    Complete strip and rebuild……not a hard job but very labour – intensive. Top off, condenser out, front off, (careful not to break the PCB behind the fascia), back panel off, heater off, unscrew rear bearing support, lift drum and unhook belt from jockey pulleys, lift drum out……..about 10 – 15 minutes with a power screwdriver. Lots of different screws used; make a note of what goes where and how many.
    Reassembly is the reverse of the above; fitting the belt on the pulleys is like any other machine; apart from Candy / Hoover driers where you have to do it through a letterbox space with one hand.
    Practice will speed the job up, but not a job I relish and you really do EARN every penny of your fee.
    HTH,
    Steve.
    #305743
    Re: candy dryer
    Take the opportunity to remount the pcb on the back of the rail, rather than the front – it’ll save you twenty minutes when that little blighter fails next.
    superspin
    Re: candy dryer
    thanks foe replies
