Candy dryer E14 error Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Candy dryer E14 error This topic has 7 replies, 3 voices, and was last updated 4 years, 2 months ago by slyp98. Viewing 8 posts - 1 through 8 (of 8 total) Author Posts January 10, 2022 at 1:16 pm #100435 slyp98Participant Hi all Happy New year, hope everyone back in one piece ,, I have this dryer ser no. 3110082920060644 pump is fine not collecting any water , I suspect NTC , but I’ve measured it at 23.5K ohms does anyone have tech info on this one cheers K January 10, 2022 at 1:26 pm #480605 electrofixModerator rear ntc problem either probe, wiring or board Dave January 10, 2022 at 4:04 pm #480606 slyp98Participant Cheers Dave , does 23.5K sound about right at room temperature Cheers January 10, 2022 at 8:29 pm #480607 electrofixModerator unfortunatly they dont give values for it so i cant say double check the wiring and check connection to the board Dave January 10, 2022 at 8:56 pm #480608 murvParticipant As a check the front and rear thermistor are the same part so should have similar readings.. Murv… January 11, 2022 at 1:07 pm #480609 slyp98Participant I did check em both , 24 K for the front so I take it they are OK and it’s prob the pcb , cheers men January 11, 2022 at 8:14 pm #480610 electrofixModerator if both thermistors are the same swop them and see if the fault changes also check wiring to board make sure you can read both ntc from the board connectors Dave August 23, 2022 at 11:25 am #480611 slyp98Participant Author Posts Viewing 8 posts - 1 through 8 (of 8 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
