Candy DWI160 Overfilling
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Candy DWI160 Overfilling
  • #34064
    sharpie
    Our Candy DWI160 has suddenly started to leak. After reading the Basic Fault Finding guide I’m pretty sure it’s overfilling as it takes a while from starting to fill and wash before the leak starts. We’ve never put salt in it and I wondered if the pressure switch could be clogged? Indeed, where is the pressure switch and can it be replaced if it’s had it?
    Ta very much,
    Sharpie
    #241090
    Re: Candy DWI160 Overfilling
    That’s an old “proper” Candy machine. Drag it out, tip it back to a good angle and look underneath. There is a black sump moulding, with a cover on the bottom retained by three screws. Undo them, pull the cover and clean the contents out – it will be full of muck of goo.
    Power off, first………
    sharpie
    That was great advice, many thanks. It didn’t work first time but I then noticed two clear tubes leading off the sump, one to the inlet valve and one to the pressure switch I guess. I blew through them both and found the one to the pressure switch was blocked. After clearing that it went through a rinse cycle without leaking.
    Now we just need to dirty lots of plates and we’ll try it properly.
    Thanks again..
    #241092
    onedel
    😯 I had same problem as sharpie , but following above advice my DWI 160 is now working perfectly, Well Done !!
