Candy Evo W6853D Problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Candy Evo W6853D Problem
  • #90263
    sheffcitylad
    Hi can anyone help. I am trying to fix a Candy Evo W6853D machine. When you turn the machine on and select the program all seems fine but when you press the start button the door lock indicator flashes constantly but the door does not lock or machine start. I have replaced the door interlock with a new one and also checked for any blockages with no luck. Still the same flashing lock indicator. There is no error code displayed what so ever so I am very confused. Any help would be gratefully appreciated, Thank you.
    #444219
    Jackcox1
    Re: Candy Evo W6853D Problem
    Check continuity across the lock to PCB wiring, Check brushes if brushed motor also check continuity across heater.
    #444220
    kaibart
    I would definitely look at the motor if you have changed door lock motor does cause the problem you have
