Candy EVOW6853D-80 PCB Part No
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Candy EVOW6853D-80 PCB Part No
  • #89671
    jag-12
    Have no motor action but motor and connections all OK so suspect main pcb
    Candy EVOW6853D-80
    31004215 1355 1105
    Connect have supplied 49023647 but it is a lot smaller board, They also list a DC pcb which is not fitted to my machine
    All the connections are the same and in the same relative positions but the board itself looks to be missing a large rectifier section.
    Can anyone confirm if this is the correct board or if not the correct part no
    Many thanks
    #442093
    kaibart
    Re: Candy EVOW6853D-80 PCB Part No
    As this machine is a dc machine it will either have a separate rectifier with 1 lead going to it or will have a dc module with the rectifier built in if so the part number is
    49023647
    #442094
    jag-12
    Part no 49023647 is the one suppplied but as photos show it is different from the original.Is it interchangeable
    #442095
    kaibart
    No the original is a dc module and the 1 they have supplied isn’t try the part number from previous post that a dc module and the 1 you want
    #442096
    jag-12
    Sorted
    4 different modules fitted to this model !
    Depends on second part of serial number
    In this case was pt no 49027658
    Thanks for the help
    #442097
    kaibart
    No problem I’m good with hoover candy having worked for themlol
