candy f112/3 door handle brackets
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts candy f112/3 door handle brackets
  • #62047
    clockworkone
    part no for oven door handle is hvr91602796. looking for part no for brackets to fix handle on.do they come seperate or with new handle.sorry have no more details at mo.taken three calls just to get mod no.paul
    #348493
    Re: candy f112/3 door handle brackets
    clockworkone wrote:looking for part no for brackets to fix handle on.
    Does the handle screw directly onto the ‘top oven door trim?’ On the drawing it shows a top and bottom door trim but only gives the part number (91800336) for the bottom trim. They don’t look the same on the drawing but I’m guessing the handle screws into the top trim, does it?
    Dunno.:con:
    #348494
    clockworkone
    thanks for reply. this job is about 35 miles from me and ladys explanation a little vague.im thinking handle as you say is on top of door as it as she says holds outer glass in.she explained that bracket on one side of handle broken, only to text later to say both sides are broken. i do this area mondays and thursdays so was hopeful of going equipped thurs.paul
    #348495
    clockworkone
    looking at pic of handle i think martin is right about handle fixing to top of door.brackets as she calls them are the fixing lugs with holes. handle is a one piece job.paul
