Candy F211x fan oven
  • #8109
    The bulb in my Candy F211x oven has gone and I cannot see how the bulb cover comes out to replace it.
    Does anyone have a manual or some instructions on how to get it off so that I can replace the bulb?
    As an aside does anyone know how difficult or not it is to replace the fan element in this oven as I expect it is going to go shortly as it is six years old now.
    Stuart
    #126896
    Dave_Conway
    Re: Candy F211x fan oven
    From the diagram it looks as if the lamp cover glass turns to release, it will either unscrew or twist slightly to release. It will probably be quite tight though if it hasn’t been removed for some time so please use extreme caution as the glass may shatter if too much force is applied.
    The fan element is behind the rear cover inside the oven, fairly straightforward really.
    #126897
    Cheers for the info. I didn’t want to force it if it was something stupid like you had to take the oven out to replace the lamp. Will try using something grippy to hold the cover to try and apply some gentle persuasion.
