Candy FF
  • #60176
    spimps
    Have a sensor to order for a fridge freezer,is there a tech bulletin for this.Thought I had one on file but can’t find it :rolls:
    #341007
    TeeMyob
    Re: Candy FF
    What model?
    Fridge or freezer evap sensor?
    TM
    #341008
    spimps
    Re: Candy FF
    Sorry it’s a CFMF2854A
    Cheers
    BG
    #341009
    TeeMyob
    Re: Candy FF
    Hello,
    Yes there is a bulletin for the FRIDGE evaporator.
    On these models the compressor can run almost continually in refigeration mode, causing the fridge to freeze food.
    The buletin “should” come with the Sensor/thermistor. It invloves stripping out the rear insulation behind the fridge evap and you should re-foam it. Screwfix or B&Q have the cheapest no frills expanding foam.
    Beware though, the dimensions given in the buletin are not always correct.
    Hope this helps?
    TM
    #341010
    spimps
    Re: Candy FF
    Cheers
    #341011
    TeeMyob
    Re: Candy FF
    spimps wrote:Cheers
    You are wlecome.
    Send me a PM if you get stuck or need any more info!
