Candy FL134W – how to clean door glass?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Candy FL134W – how to clean door glass?
  • #44952
    Kommunist
    Last year I bought Candy FL134W built-in oven. It works OK, but nothing to write home about, TBH.
    Recently I had to prepare a BIG meal (family and friends came round) and I used grill a lot. Then I noticed that there are white grease lines inside of the oven’s door. Not only that – it also somehow got into oven’s timer.
    The question is how to clean inside the door and front panel? I looked in user manual but it doesn’t say anything about door cleaning procedure.
    Any ideas?
    P.S. I know buying Candy oven was a mistake 🙂
    #283082
    spimps
    Re: Candy FL134W – how to clean door glass?
    Usually with the cheaper manufactures the door would have to be removed and then screws either at the top or bottom taken out to split the door.
    I see with this model there is a tool sold for door removal by GIAS,depends on what hinges are fitted as usually you can lock the hinge to enable it to be removed from the body but I’m not familiar with this model.
    Front panel UNPLUG FIRST,you would have toremove the facia,again screwed and to do this it would have to be removed from cupboard.
    Cook first wine later,less messy 😉
